2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-14T21:33:46+00:00
    Dear MadMac,
    The first above solution should work as long as you reset your device's hardware status. Try the following solution...
    1. Shutdown.
    2. Simultaneously press and hold Power + volume up buttons for 15 sec before letting go of both buttons
    3. Let it sit for another 10 sec
    4. start it up
    5. Re-set your date and time.
    2013-12-15T02:46:50+00:00
    The idea below does NOT work for me i followed the info meticulously and when installing at the end it stops at 20% saying install error - so i wont even attempt this again
    http://systemsadminguy.wordpress.com/2013/11/16/how-to-update-surface-pro-2-recovery-image-drivers/
    Thank you Microsoft for realy realy runing my experience and wasting so much of my time - and still NOT fixing anything :¬( grrrr.
    I know 6 other people who have performed the steps on the blog and it's worked perfectly for them. It sounds like maybe you have a bad USB thumb drive OR a faulty SP2. Maybe take it back to where you got it from and do a warranty claim.
