2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-14T08:26:26+00:00
    Hi
    I came here to find answers as I have issues with the firmware update "Failed". Just happy not to be alone in this issue. I am afraid this is all too familiar to me with MS update policy and general shoddy workmanship. No accountability and pushing out data updates that do not "mesh" with users platforms. This is becoming the "norm" for update Tuesdays. KB2670838 is still an issue with Win7 users also the "new" X-box 'brick' updates!
    I just find this type of dysfunctional software/firmware data publishing unacceptable. Bad workmanship and no "QA" is very bad press and will drive away business! Just not acceptable for a new computer and established(!) software manufacturer...
    Where is Mr. Fix-It?...Oh my noted problems, excessive battery drain, Bluetooth mouse lag, and for some reason; OneNote Office 2013 not syncing(pro2 128)
    2013-12-14T13:34:20+00:00
    This December update is useless
    I am now back to battery flat overnight again :¬( grrr
    I don't quite know what to do apart from reset back to factory and ONLY do the fix as david1234 explaines on the link below (This alowed my SP2 to stay charged for about a week with very little use)
    http://answers.microsoft.com/en-us/surface/forum/surfpro2-surfupdate/surface-pro-2-surface-cover-telemetry-driver-blank/c5c4508a-d23f-4bd3-8631-d851d8f776a3?page=7&tm=1387027892086
    The idea below does NOT work for me i followed the info meticulously and when installing at the end it stops at 20% saying install error - so i wont even attempt this again
    http://systemsadminguy.wordpress.com/2013/11/16/how-to-update-surface-pro-2-recovery-image-drivers/
    Thank you Microsoft for realy realy runing my experience and wasting so much of my time - and still NOT fixing anything :¬( grrrr.
