2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-14T02:31:03+00:00
    I am sure they are aware of this issue and working on a fix. I am nevertheless happy with my SP 2, this being just a minor inconvenience and first update problem I have ever had. So don't despair, give them some time to work on this.
    2013-12-14T06:35:03+00:00
    Here is what helped in my case:
    After several unsuccessful attempts to do WU service stop/purge/repository repair as described in this thread, I decided to look a bit more closely at the process tree/wait chains for a single patch that would repeatedly hang: KB2850063 for OneNote in my case.
    At the time of the apparent hang it would have about 4 msiexec subprocesses with an msiexec waiting on another one which in turn was waiting on spoolsv.exe - "Print Spooler" windows service.
    The patch installer successfully finished after stopping Print Spooler.  Same for a couple drivers that I also hadn't been able to install prior.
    This may not apply to everyone and is most likely specific to OneNote print emulation.
    Just in case it does help.
    Alex.
