2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-14T02:05:29+00:00
    Same here, 4th reset. So tired, and too afraid to perform an update ever again. This had been a "When Virosoft met Microsuck" nightmare.
    2013-12-14T02:24:27+00:00
    Has Microsoft commented on this at all? It's affected everyone I know who's tried the update. Maybe should get tech bloggers involved. This shouldn't be something that needs tinkering to fix. Why the heck isn't MS pushing an update to fix this, or at least a hotfix?
