2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-14T00:17:53+00:00
    Today I again am having the battery issue reporting incorrect Full Charge Capacity number. I'm not sure what happened. Again, I did the volume up+power button combination and it recovered my battery back to the normal state. But seems this just fixed the battery issue temporarily.
    2013-12-14T01:58:43+00:00
    I finally gave up and did the factory reset and did not install the firmware update.  I hid it in windows update and all seems to be working as before the update.
