2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-13T22:34:42+00:00
    This is how I fixed it.
    Went to Disk Cleanup
    Clean up system files
    Checked cleanup windows updates, I have not seen this option before.
    It took about 30 minutes to an hour, task manager showed it was working.
    It told me to reboot, did not see it update the firmware, it seemed to restart fast but after reboot it showed it succeeded
    Surface pro 2 128 gig
    seems to be working fine
    Is there a way to check what the latest firmware should be and what version should be?
    2013-12-13T23:51:07+00:00
    Thanks mcboise running system disk clean up with windows update clean up solved it for me too.  Though only took a few minutes to run.
    After the firmware update appeared and this time succeeded.
    Now switched back to the balanced power profile, and will see if the sleep/hibernate function works now. :-)
