2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-13T21:22:16+00:00
    After running Dylan Tullberg's repair method (see Most Helpful post, start of thread) and getting Hardware Update, then Win8.1 driver update (on 12/12/13), my Marvell Avatar network and Bluetooth drivers are dated from 11/8/2013.  My Type Cover 2 Firmware update driver (Human Interface Devices) is still from 10/23/13.
    Hope this info helps.
    2013-12-13T22:05:15+00:00
    So I wasn't really having any problems with my sp2 128 other than needing to turn off the power management of the wireless.  I updated to the new firmware and it failed.  I tried to do a restore to a few days before the update.  Thate turned into a mess and my only choisce was to do a resfresh thinking the drivers would be ok.  Now it turns itself on from sleep in the middle of the night and the battery drains really fast. It seems to run warm all the time. Last night i injected the driver using system admins method and none of the drivers are updating. Any one have success with the latest patches if they have done a refresh. Whatb did you do.
