2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-15T00:01:07+00:00
    Nightmare returned. "System Firmware update - 2/11/2014" has started to come with every daily Windows update. I've seen similar after the December update and spent a lot of time to get rid of this. The same update comes and installed without issues every day, every day.  It's never stop!  Couple days after Feb update it did not come, but today begun.  I did not touch my SP2 last days and kept my fingers crossed, why did it start? Something fundamentally wrong in Windows Update procedure for Surface.
    Alex.
