2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-14T11:40:00+00:00
    Dear TBone,
    I have 3 x Surface Pro 2s and am using a SanDisk Ultra 64Gb MicroSD cards.
    All of my 3 units displayed exact same signs of the problem.
    These are as follows...
    1. Cold-booting a BRAND-NEW out of the box SP2 with the MicroSD card inserted and leaving the unit idle for 30sec, Task Manager opened showing CPU usage sorted view. Hogging the CPU is the Client Server Runtime (csrss.exe). The 40%-60% csrss.exe lags the system to the point where starting applications are a pain and scroll or swipes gestures at the Start Screen are no longer smooth.
    Solution: Put the unit to sleep and wake it back up to temporary rid the problem.
    1. Once updated to October Firmware and above... Cold-booting SP2 with the MicroSD card inserted and leaving the unit idle for 30sec, Task Manager opened showing CPU usage sorted view. Hogging the CPU are System (ntoskrnl.exe) & System Interrupts. The 30% ntoskrnl.exe does not visibly lag the system, but battery hungry enough to ruin your day, every day.
    A Jurassic issue cross-threaders can read all about HERE... something which plagued all of my 3 x SP2 units, Tried updating the SD-SLOT driver in the Device Manager but there isn't one. You can try updating the SD-Card driver after you insert it, but the best driver has already been applied. Hope I make sense.
    PMR.
    I have just tried a cold boot. I have the SanDisk MicroSD card plugged in and do not have any CPU usage issues. Not sure there is much else I can offer to help.
    What size is your MicroSD card and how was the card formatted? exFat, Fat32 or NTFS?
    2014-02-14T11:44:47+00:00
    Battery life after the upgrade firmware , I understand that there are other problems but I think this is very important, no sense a tablet with this battery.  And CPUID show thet max temperatura in proccesor is 165F , and the average temperature will be around 110F-120F
    Could you elaborate what happened? Did your unit heat up to 74ºC for two hours with the cover closed? Which region do you live in and what is the typical day temp there? Did you have the tablet in a bag?
