2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-13T23:44:28+00:00
    Have you tried system restore prior to the February update?
    2014-02-14T11:27:52+00:00
    Battery life after the upgrade firmware , I understand that there are other problems but I think this is very important, no sense a tablet with this battery.  And CPUID show thet max temperatura in proccesor is 165F , and the average temperature will be around 110F-120F
