2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-13T19:55:29+00:00
    Hi, I'm sorry to disappoint you, but I can assure you that I know how to find my way with Windows. My event log doesn't show ANY ID 41 error. I have a couple of Bluetooth related errors and that's about it. I had sleep/hibernate/battery problems since December, they were partially fixed with the January update and completely gone with the February update. I don't know what to suggest you, but it's not useful to scare people into thinking that even if it looks to them that their SP2 works it might be silently crashing on them. There is enough evidence to prove that the problems have been solved in many cases. I'm sorry if this is not your case.
    2014-02-13T19:55:33+00:00
    Greetings,
    Just to confirm, it is not possible to roll back firmware. I've seen posts that say the Battery meter issue is fixed, and posts that say it is not. Please ensure that you have installed all Windows Updates, and checked again if you are not sure, to ensure that all updates are installed.
    I have not see any posts around Firmware showing as failed in Windows Update, which is what this thread was originally about.
    I have seen a few posts that the Surface now Sleeps or enters Hibernate correctly, and some that are saying it is not happening.
    So I can correctly pass information back to the appropriate teams, I need a direct, Yes these (above) are working now, or No they are not.
    Dear Steven,
    No. Hibernate fails 90% of the time for me. I effected Feb-update successfully on 2/11 and no positive change in hibernate entering/resuming for me.
    Same for me
