2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-13T06:00:11+00:00
    What exactly did you do to make the battery capacity back to 44k? I rerun "powercfg /batteryreport" several times and it always shows 22k to me.
    follow the steps below
    1. Shut down.
     2. Hold vol + and power button for 15 sec. Surface logo may flash etc. but don't let go for 15 sec.
     3. Let go of both buttons
     4. wait 10 secs.
     5. Press power button to start up.
    Yes this reset really works. Adding it to my SP2 button combination arsenal!
    2013-12-13T16:31:24+00:00
    I do the same, thanks
    no unknow device
    But after december update, my Bluetooth/graphic/wifi/touch cover driver are still from octobre driver pack...not from december...wtf..
    Need help please
    Is msft release the december drivers pack ?
