2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-13T16:49:28+00:00
    You guys all REALLY need to look in your system event logs and look for EVENT ID 41.  This is NEVER a good thing.  It is an unexpected shutdown event when the system crashes usually during sleep or wake or hibernate.
    Those of you thinking your Surface's are working NEED to look at ACTUAL data and stop using your gut.
    EVERY Surface Pro 2 I have worked on has experienced these issues and the end user is just not fully away of them.
    I've searched through my event log and there are no EVENT ID 41.
    Going through the list the only device related ones I've had since installing the February updates are (loosely translated from Swedish):
    Errors:
    MTConfig EVENT ID 1: Failed to configure input method for a multitouch device.
    BTHUSB EVENT ID 17: The local Bluetooth-card did not work in an undefined way and will not be used. The device driver has been inactivated.
    DeviceSetupManager EVENT ID 121: The device driver couldn't be installed, result=0x8024402C for devnode{5494A00A-6AE1-4641-AD07-0DC2FAB88BC}\SURFACETYPECOVER\8&21DD112B&0&10
    Warnings:
    Display EVENT ID 4101: The graphics driver igfx stopped responding and has been reset.
    My Surface Pro 2 has worked fine though, no issues with waking it or using my type cover 2.
    2014-02-13T17:16:10+00:00
    This is maddening....
    The Feb firmware did not resolve these issues and with the feb firmware my surface no longer goes to sleep at all when closing the lid.  After rollback it does.
    Also those of you that keep saying you can't rollback firmware on a surface are also ill informed.  When you reset a surface pro the firmware absolutely reverts.  Same with the firmware patches.  They CAN be reverted.  Microsoft built this in i would assume to prevent bricking devices by a bad firmware update.
    Instead of just making comments based on your semi knowledge of firmware for other products you should make sure you understand how it actually works on a Surface.   Here is a tip, actually look at the firmware version in device manager and roll it back and see it revert.
    David,
    I'm really not sure anyone is prepared to argue with you about this.  You may indeed be very right about what you're saying.   But, this thread is filling up with people who have achieved resolution with the Updates on Tuesday.  Yet you are still screaming the sky is falling.   Again, you may be right.  But yelling ID 41 doesn't help anything.  The vast majority of people here, do not understand what that means.  You can't argue away they are not of value, because they do not understand what you are saying.  You point them to the Event Viewer and they see red, and freak.
    Why don't you be more specific about what you want people to look at, and why.
    For me, I currently have 5 ID 41's.  2 are power down related and 3 are sleep related.  But I have NONE since the update was installed.  According to what you have written, I should be freaking out, but this update was supposed to deal with battery meal and restarts from Sleep problems.  For me, I would call this a success so far, but according to you I should still be freaking out.
    Help us all out by being specific at what you think people should look at, and why...what's the impact.  We're not all system engineers with 20 yrs experience.  Help us understand what you're saying.
    after the feb update I was also getting the Event ID 41,  however,  I turned of hibernate which deleted the hibernate system file,  also,  I set the swap file size to 0,  rebooted then set the swap file back to default, and turned hibernate back on.
    since then I have not had any event id 41 errors.
