2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-13T01:30:04+00:00
    I did perform a system restore to a system restore point created prior to the updates. This removed the updates and rolled back the firmware update.  NOw my system is functioning fine.
    I understood that a system restore did not roll back firmware updates. Was that information incorrect?
    Correct. A restore won't roll back firmware.
    Perhaps firmware wasn't something discussed in his 20 year system engineer career.
    There are software components that work with the firmware, which is probably what he's thinking of.
    2014-02-13T02:10:33+00:00
    Greetings,
    Just to confirm, it is not possible to roll back firmware. I've seen posts that say the Battery meter issue is fixed, and posts that say it is not. Please ensure that you have installed all Windows Updates, and checked again if you are not sure, to ensure that all updates are installed.
    I have not see any posts around Firmware showing as failed in Windows Update, which is what this thread was originally about.
    I have seen a few posts that the Surface now Sleeps or enters Hibernate correctly, and some that are saying it is not happening.
    So I can correctly pass information back to the appropriate teams, I need a direct, Yes these (above) are working now, or No they are not.
