2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-12T22:28:57+00:00
    I did perform a system restore to a system restore point created prior to the updates. This removed the updates and rolled back the firmware update.  NOw my system is functioning fine.
    I understood that a system restore did not roll back firmware updates. Was that information incorrect?
    2014-02-12T23:46:23+00:00
    I've got my SP2 for a couple of months now and I have only experienced the battery-meter-issue-thingy once. A reboot and it sorted itself out.
    Regarding the FW Upgrades etc. the 11.feb 2014 update gave me a "Unknown Device". Pretty much the same as the cover telemetry driver as beeing described above.
    Though never (and still don't) have any sleep or hibernation errors.
    I'll keep you guys updated sometimes tomorrow as I might figure out some more.
    Yashin_AL; Keep me posted!
    Did a sfc /scannow and Windows made "some" repairs.
    Went for another Windows update, got a whole bunch of .net updates (bundled with some other W8 / 8.1 updates).
    Did a reboot, now the telemetry device is working properly (by working, meaning not showing any warning in the Device manager)
