2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-12T22:21:27+00:00
    So far my SP2 works a lot better after the recent updates. The type cover and battery seem reliable again.
    Going through the event log there's been a couple of event 4101 (video driver crash) and some MTConfig errors.
    There's also quite a few info and warning messages about BTHUB, inactivated drivers due to odd behavior and failures to save bluetooth authentication keys. My bluetooth devices works fine though so I guess it is nothing to worry about.
  2. Deleted
