2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-12T21:16:39+00:00
    +1 to Event 41's.  Just had my first after 2/11/14 firmware update.  Had to reboot SP2 after "sleeping"
    2014-02-12T22:11:55+00:00
    I've got my SP2 for a couple of months now and I have only experienced the battery-meter-issue-thingy once. A reboot and it sorted itself out.
    Regarding the FW Upgrades etc. the 11.feb 2014 update gave me a "Unknown Device". Pretty much the same as the cover telemetry driver as beeing described above.
    Though never (and still don't) have any sleep or hibernation errors.
    I'll keep you guys updated sometimes tomorrow as I might figure out some more.
    Yashin_AL; Keep me posted!
