2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-12T20:20:36+00:00
    Greetings all,
    Please download the February Windows Updates. You may need to install current updates, restart then check again to get all of the updates.
    Once you have all Windows Updates installed, please let us know if you are still experiencing the following:
    Firmware showing as failed in Windows Update
    Battery gauge on your Desktop showing incorrect time/battery levels
    If your Surface will not go into Sleep while idle
    If your Surface will not go into Hibernation.
    Firmware and other updates installed successfully.  My Battery gauge has returned to normal.  I have not tried the sleep or hibernation as of yet.
    2014-02-12T20:37:39+00:00
    Greetings all,
    Its my second SP2, the first was returned because of the December update firmware.
    Everything in this new device was perfect until yesterday,  since the February update firmware , during installation a very strong fan noise is heard, the battery life is ridiculous now, and again i can see unknown device and error in Surface cover telemetry. Besides i think the CPU temperature is higher now . I cant believe it ... this is a nightmare.
