2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
  1. Deleted
    2014-02-12T18:49:13+00:00
    Feb firmware and all patches applied successfully according to update history. SP2 256 is working great now. Sleep works without issue. No crashes in event log. Battery meter no longer shows whacky numbers. Touchpap on touch cover works much better now.
    I really feel for folks who are having issues, but the last patch has solved most of my issues. The only outstanding issue I have is the excess CPU sometimes when I boot with SD card installed.
