2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-12T17:47:45+00:00
    Did you check your update history to make sure the install did not report as failed?
    I am a microsoft systems engineer of over 20 years experience. I know what I am doing.  In fact I helped identify these issues in the first months when nobody from Microsoft would listen.
    My new system purchased on Feb 12th(previously purchased 1 on launch day and had it replaced 3 times but then returned it in early February to protect myself.  The new device was stable until the firmware update was installed last night. The install said successful but my surface pro stopped going to sleep when closing the lid.  I had to use the power button + volume button several times since last night to even get the unit to boot up.
    I did perform a system restore to a system restore point created prior to the updates. This removed the updates and rolled back the firmware update.  NOw my system is functioning fine.
    It doesn't get any clearer than that.
    Check to see that the update even installed for you I've read several reports where it failed.
    Check some of the other forum posts for people reporting issues with this new firmware update.
    If you were talking to me, no, I did not check the History.  I had no real reason to think anything had gone wrong.  I've said it before, the day I can't reliably do an update, is the day I throw the device away and get a different one.  Other than some angst right around install, there was not an indicator that anything was wrong.  I was at work, working, not digging into what Microsoft did or didn't do this time around.  The Update pop up was a surprise to me.  When it installed, there were no issues.  Going back through my Update History now, I do see it failed originally.  But again, I would not have known that, or even been drawn to checking it since I had no indicator I was on the brink of oblivion.
    The device is NOT hot, not running fans.  I see no indicator of excessive CPU usage.  I touch Power, it goes to sleep.  I touch power again, it restores.  I close the lid, it goes to sleep.  I touch the Power, it wakes.  I tried all of that right now while this reply was open.  There was no rebooting.
    I understand why people go looking for issues.  I understand that others may not see the issues  others look for.  I don't understand how TrevM's device crashes and bluescreens, when mine does not.  Is there a configuration difference between our machines?
    I am a Supportability PM with many many years of experience, just like you.  I understand how to work through these things.  I also know there is a reason why your device does what it does while mine may not.  What is it that is different on my machine that is not, or is exclusive to mine or yours, that produces different results.
    I have used my Surface devices at work, everyday since day 1.  I have lost 2 days in all that time to Update issues.  I have no backup.  There is no other machine to turn to.  The Surface has had to work for me, or I don't work. It has not failed me.  Why is that?  Why is your Surface reacting in such a way that requires you to send Apocalyptic email?
    If you can't or are unwilling to check your update history then your add no value here.  Many users have reported installing these firmware updates with no visible failure but if you check the update history you will see the update failed.  Especially since you mentioned that the update was offered to you multiple times I think the update never applied and your system is having issues.   Don't use the force.  Your not a real Jedi.  Look at the logs and use facts and data to create conclusions.
    Seach your system logs for EVENT ID 41.  These are unexpected shutdowns.  I bet you don't even realize your system is crashing...  In every case of someone I have worked with who thinks it is operating perfectly they just aren't experienced enough to realize the system is crashing because the solid state drive is so fast and it boots up quickly.
    PS, the hardware is identical in these units.  This is a software issue in most cases.  Microsoft couldn't even be bothered to put a functional recovery image on these devices.  When you do a full reset the surface cover telemetry driver does not reinstall properly.  That issue has been ongoing since launch.
    I accept what you say without an issue.  I was not unwilling to check anything.  I said I had no reason to believe anything went wrong.  I'll look at what you wrote and check it out.   But I remind you about value add...sending the mail you sent, is also without value.  Speaking to that point, is where I was going.
    2014-02-12T18:08:59+00:00
    All Updates installed - yet continues to crash - seems to sleep but crashes during sleep.
