2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-13T03:19:35+00:00
    What exactly did you do to make the battery capacity back to 44k? I rerun "powercfg /batteryreport" several times and it always shows 22k to me.
    2013-12-13T03:19:43+00:00
    Hi, wipe fixed edition of SP2 here...
    All was working well except for the battery meter. Just receive the 2nd System Firmware Update - 12/10/2013 (same date). So now I have 2 x off the same System Firmware Update present. It was around 400+kb. Seems the battery meter is fixed with this update.
    Repair details:
    1. Wipe
    2. Update Surface Cover Telemetry Driver with October Surface Pro 2 firmware and driver pack & used it to fix Ethernet/Wifi/Bluetooth drivers afterwards.
    3. Ran first Windows Update.
    4. All working well except battery meter
    5. Received another "System Firmware Update - 12/10/2013" at 2:00pm (+10 Australian time).
    6. Fixed!
