2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-12T01:28:56+00:00
    BTW, don't know if everyone following this thread is automatically hooked up to follow the "Windows 8.1 - Strange Charging Issue" thread.
    But in that thread Steven_B, a Microsoft Forum Moderator, is urging everyone to be sure to install the February firmware update as he says it addresses the issues of incorrect charge level being reported by the battery status indicator:
    http://answers.microsoft.com/en-us/surface/forum/surfpro2-surfhardware/surface-pro-2-windows-81-strange-charging-issue/5d922bc6-15a8-47d7-8c19-1080d81dfcf6?page=8&msgId=0f27571f-2440-4030-87b6-2ad6da7585f8
    EDIT:  Looks like the man himself visited this forum while I was composing this post!
    2014-02-12T02:47:01+00:00
    Just installed the 12^th^ of February firmware update and I got the "sleep of death" problem back I had on the 10^th^ of December firmware update.
    Need to restart the SP2 fully every time it goes to sleep. Now it actually does not wake up from sleep at all. On the bad December update it actually woke up sometimes after a while.
    The "sleep of death" problem was ‘”fixed” after the 18^th^ January update, and have not had many issues with the sleep problem before today.
    Michael
