2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-12T00:20:48+00:00
    Sorry for upset. IMHO, MS Surface is the only tablet which really powerful as a regular notebook/desktop. Nobody builds something like this right now. But this is startup time. Wait next month and they will fix it all. I use SP2, my wife uses Apple Macbook and I have much more problems with hers laptop. But you're right - powercfg and yada, yada just now.
    Alexander.
    2014-02-12T01:28:41+00:00
    Greetings all,
    Please download the February Windows Updates. You may need to install current updates, restart then check again to get all of the updates.
    Once you have all Windows Updates installed, please let us know if you are still experiencing the following:
    Firmware showing as failed in Windows Update
    Battery gauge on your Desktop showing incorrect time/battery levels
    If your Surface will not go into Sleep while idle
    If your Surface will not go into Hibernation.
