2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-11T22:50:49+00:00
    Jim, do not worry. They are normal temps for any computer. Normal processor's temp should be 110-150F in any comp. It warms around. Can you feel the heat by your hand?
    2014-02-11T23:35:56+00:00
    Hi, Al
    Am not worried about my SP2 temps.  Was replying to Rafa Roma's comment that he thinks his SP2 runs hotter after the Feb. firmware update.  I haven't noticed any temperature differences.  Any temp worries I would have would not be about the processors per se but the effect on overall temp of the device and battery life.  But my SP2 is doing great temperature-wise.  Only time I ever hear fans come on is occasionally upon Shutdown.  Weird as it doesn't seem to be connected to how much the device has been used???
    Hope Microsoft builds a better natural interface to battery state into upcoming Win8 updates, 2015 Threshold, yada yada.  The average Win8 consumer users is not going to want to mess with Administrative Command line prompts ("powercfg") or esoteric utilities like CPUID.  All the stuff essential to following the state and health of your device should come baked in in a readily discoverable, easy-to-use interface.
