2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-11T21:48:36+00:00
    My SSD temp is now 71 deg F, both core temps are 87 deg F by CPUID after installing, uninstalling Adobe Reader XI version (moderate CPU workout), opening & closing a number of PDF files-- but my house temp is currently 58 deg F!  Before the most recent firmware update, I've seen my cores hit 140 deg by CPUID after high usage but I rarely see them above 100 deg F.  Summer, when we let the house temp go up to 85 deg F, will be a different story....
    2014-02-11T22:02:29+00:00
    Ditto! Radio adapter driver update has been issued only for Sirface Pro, not for SP2.
    Surface 2 update history:
    February 2014 updates
    • Marvell AVASTAR Bluetooth Radio Adapter (v14.62.28058.10171)
      • Improves Bluetooth® audio related issues.
      • Resolves issues related to Bluetooth keyboard and mouse inavailability when waking Surface.
    • Marvell AVASTAR 350N Wireless Network Controller (v14.62.28058.10171) resolves wireless network connectivity issues.
    YEAH, The wife has a SP1, and updated this driver.  Afetr rebooting and power down and disabling and enabling, she has no WIFI.
    Delete the network Interface card under "Device manager" and reinstall it with the drivers from the January2014 pack.
    I had to do this as well.
    http://www.microsoft.com/en-us/download/details.aspx?id=38826
    Did you find this helpful?
