2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-11T21:35:05+00:00
    Probably Microsoft uses smart update which compares drivers versions and installs only new ones. So if you have fresh SP2 installation then it could install all of them. We could compare our drivers versions in private mail.
    Alexander.
    alexander AT solaat.no
    2014-02-11T21:43:53+00:00
    Ditto! Radio adapter driver update has been issued only for Sirface Pro, not for SP2.
    Surface 2 update history:
    February 2014 updates
    • Marvell AVASTAR Bluetooth Radio Adapter (v14.62.28058.10171)
      • Improves Bluetooth® audio related issues.
      • Resolves issues related to Bluetooth keyboard and mouse inavailability when waking Surface.
    • Marvell AVASTAR 350N Wireless Network Controller (v14.62.28058.10171) resolves wireless network connectivity issues.
    YEAH, The wife has a SP1, and updated this driver.  Afetr rebooting and power down and disabling and enabling, she has no WIFI.
