2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-11T21:25:59+00:00
    I got 20 updates including the firmware (351 kb), 1 optional, and and English input personalization update.
    Hard to tell from Al Yashin's listing whether the SP2 is fixed by updates for onscreen keyboard appearing when Type 2 cover attached or resets when Type Cover attached/detached.  Hope so as I had occasional issues with both..
    Hard to tell with SP2 but February updates definitely seem to speed up IE browsing on Surface RT.  Hope same is true for SP2.  RT browsing is MUCH less pokey.
    On battery wear level, I've noticed device temperature definitely factors in.  By CPUID readings, my device usually shows 1% wear level at ~20 cycles and my SSD temperature is usually in the 60 to 70 deg F range (cold house).  With intensive use, when my SSD heats up to 75 to 80 deg F, the wear level shown will often drop to 0%.  (CPUID has no direct reading of battery temp).   My Surface RT at close to 100 cycles shows 0% wear (has a different battery and wonder whether battery report is even working correctly!).
    So no issues with February Patch Tuesday updates (fingers crossed).
    2014-02-11T21:33:52+00:00
    My first impression, temperature in processor seems higher now, and battery life will be short.
