2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-11T20:53:29+00:00
    Probably Microsoft uses smart update which compares drivers versions and installs only new ones. So if you have fresh SP2 installation then it could install all of them. We could compare our drivers versions in private mail.
    Alexander.
    2014-02-11T21:23:34+00:00
    Alexander.
    Strange Occurrence--I have a 512 4300 & a 256 4200--Firmware Update for the 512 120Meg--Firmware Update for the 256 95Meg--I Wonder why?
    And they both seem way bigger in size then some of you are getting!!
    Also I had never Installed the Jan 17th Firmware on either of Pro's had them hidden now the are gone!!
    Jack
