2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-11T20:23:09+00:00
    Run Windows update again. I got the fw update on second run, after installing the first batch.
    Thanks- update was successful. Just home it starts to fix some of the problems with standby - fingers crossed.
    2014-02-11T20:30:47+00:00
    Due to a Windows bug I had to reinstall my SP2 (done just this moment).
    Figures, when I do a scan for Windows Updates, a Third FW upgrade appears.
    This one is no less than 29.3 Mb
