2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-13T02:25:04+00:00
    In regards to the "Unknown device" in Device Manager that others have been seeing, I had that happen in the past due to doing a (factory) reset on the Surface Pro 2.
    See http://forums.wpcentral.com/microsoft-surface-pro-2/248304-major-problems-surface-pro-2-unexpected-shutdowns-sleep-issues-unknown-devicedevice-manager.html
    (I also posted my observations in the above thread.)
    Someone there also posted a permanent fix by adding the missing driver to the recovery image:
    http://systemsadminguy.wordpress.com/2013/11/16/how-to-update-surface-pro-2-recovery-image-drivers/
    2013-12-13T02:57:17+00:00
    I would try running "powercfg /batteryreport" at the admin Command Prompt as suggested by Vasan (and by myself in an earlier post) and look at the CAPACITY REMAINING COLUMN (not the Full Charge Capacity).  The results of batteryreport.html might also be erroneous because of the failed firmware update but it's worth a try to see if it gives you more accurate results.
    I saw this over on the surfaceforums.net site... it tried this and it actually worked.  My batter capacity was at 22k and after this, reset back to 44k.  My battery percent before doing this was about 88% and after went down to 42%, which is more realistic as I've been on the device all day, on and off.
    I had a similar problem. Mine was charging but the indicator was stuck at 7%. Try this (for Pro only):
    1. Shut down.
    2. Hold vol + and power button for 15 sec. Surface logo may flash etc. but don't let go for 15 sec.
    3. Let go of both buttons
    4. wait 10 secs.
    5. Press power button to start up.
