2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-11T20:13:36+00:00
    No update fir me yet - I ran window update was 18 updates but no firmware.
    2014-02-11T20:19:27+00:00
    Run Windows update again. I got the fw update on second run, after installing the first batch.
