2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-11T19:56:35+00:00
    Ditto! Radio adapter driver update has been issued only for Sirface Pro, not for SP2.
    Surface 2 update history:
    February 2014 updates
    • Marvell AVASTAR Bluetooth Radio Adapter (v14.62.28058.10171)
      • Improves Bluetooth® audio related issues.
      • Resolves issues related to Bluetooth keyboard and mouse inavailability when waking Surface.
    • Marvell AVASTAR 350N Wireless Network Controller (v14.62.28058.10171) resolves wireless network connectivity issues.
    2014-02-11T20:09:52+00:00
    I don't know about the battery percent being accurate. I ran powercfg /batteryreport and to my dismay, my surface shows even less charge capacity after this firmware update. I'm now at:
    39,842 / 42002 or roughly 5% loss compared to before the December update with about 29 cycles.
    well, my newly less lasting surface pro 2 did have one positive change, it finally installed the cover telemetry drivers and the device manager is now clean of errors.
    it is too bad the battery on this thing isn't replaceable specially given how poorly MSFT has handled battery management with this firmware flip flops.
