2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-11T19:49:36+00:00
    Just rebooted the Surface Pro 2 and got a New FW update in line.
    This time it's the 351Kb version.
    2014-02-11T19:50:13+00:00
    I still can't found what exactly was upgraded. I've Marvell AVISTAR Radio Adapter 11/8/2013 ver 14.69.24049.160. Probably Embedded Controller Firmware has been upgraded, now its Driver version 24.0.50.0, but its Driver Date is 12/26/2013!
    This is February updates description from Microsoft's http://www.microsoft.com/surface/en-us/support/install-update-activate/pro-2-update-history.
    February 2014 updates
    • Surface Display Panel (v1.0.2.0) provides tuning to the Surface display calibration.
    • Surface Pro Embedded Controller Firmware (v24.00.50)
      • Resolves issue where Surface would not go into hibernation.
      • Resolves issue where available battery percentage was reported incorrectly.
    • Surface Pro System Aggregator Firmware (v2.04.0150)
      • Resolves issue where Surface would reset upon repeated Surface Cover attach/detach.
      • Resolves issue where On Screen Keyboard would unexpectedly pop-up even though Surface Cover is attached.
      • Resolves issue where Surface Cover is not detected after wake up from sleep.
    • Surface Touch Cover 2 Firmware Update Device (v2.0.228.0) update improves two-finger touchpad use.
    • Surface Type Cover 2 Firmware Update Device (v2.0.226.0) update improves two-finger touchpad use.
