2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-11T19:26:47+00:00
    Got here. 351KB for SP2, installed successfuly.
    Alexander.
    I got 18 updates 17 normal & 1 optional but NO Firmware...
    Jack
    2014-02-11T19:42:09+00:00
    Microsoft rolls out Feb firmware update (http://www.winbeta.org/news/microsoft-rolls-out-firmware-updates-surface-pro-2-and-surface-2-fixes-various-issues), updating the Marvell Bluetooth Adapter and Touch Cover 2 Firmware.
    Link provided so people do not have to copy and paste.,
