2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-11T18:16:11+00:00
    No update available here, I think this is for the Time Zone.
    2014-02-11T18:35:17+00:00
    Just got the update here. The FW update is one among many, though only 205kb
    I'm located at UTC +1
