2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-10T20:32:02+00:00
    Thanks for the update, stur2009.  I agree with you about the staff at the Las Vegas Store, this is where I also bought my 128GB unit.  I believe that you are correct about the firmware, very disappointed based upon the numerous issues considering the price point of the product.  I pray most of our issues with the unit is based upon tinkering to optimize with the power covers.
    2014-02-11T17:42:23+00:00
    Microsoft rolls out Feb firmware update (http://www.winbeta.org/news/microsoft-rolls-out-firmware-updates-surface-pro-2-and-surface-2-fixes-various-issues), updating the Marvell Bluetooth Adapter and Touch Cover 2 Firmware.
