2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-08T11:29:57+00:00
    Hi
    Have you tried to uninstall the Bluetooth Device under Device Manager and re-install it?
    Also, have you tried to download and install the latest drivers form the driverpack?
    http://www.microsoft.com/en-us/download/details.aspx?id=38826
    2014-02-09T20:21:33+00:00
    After a couple of months, with a reset and rebuild or programs,  several calls to support, some over 2 1/2 hours long, 3 case #'s... No Windows update program available(corrupted), No restore points being available, even though they are shown in the program, but unable to restore, Device manager unable to update software programs ...I have exchanged my 128GB for a new unit directly from Las Vegas Microsoft Store. The process was easy and the employees very helpful. I have disabled the recommend setting in the update program to allow me to decide which updates to install. I have not installed the latest Firmware update. I have no intention of installing anything until it is proven. I had learnt my lesson a few years ago with Window 7 updates. NEVER rush to install something that is not proven!
    Now unhooking from this thread...
