2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-08T00:21:18+00:00
    Hey Jack,
    I got mine back on via Settings/Charms, Change PC Settings>PC and Devices>Typing>Touch Keyboard (ON=Play key sounds as I type)
    Then RESTART!
    It took a Shutdown/Restart to get the clicks back on.
    Good Luck!
    Well I gave that a shot (they were already on by the way} turned off rebooted turned on rebooted again--still no clicks when typing only a slight sound when tapping the touchpad...
    Jack
    2014-02-08T11:14:13+00:00
    Well, my cover 2 is working ok.
    However, since receiving my replacement refurbished Surface Pro 2, I cannot get my bluetooth headset to connect, my microsoft mouse (the one with Surface), or my Wireless Adapter (bluetooth as well) for the Covers I have, none of the bluetooth devices pair... or are seen at all by this replacement Surface.  Now I'm bummed.  I really did NOT want to have to contact Microsoft again.  I thought this one was going to be alright, despite it overheating once and twice getting an error message that the Display adapter failed and left me with a black screen.
    I did triple check airplane mode (off) and bluetooth modes (on) in two places and double checked device manager says it's working ok.
