2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-07T16:14:22+00:00
    Decided to factory reset my SP2 again today for the 2nd time. The 1st time was back in Dec after the failed update. Jan firmware seemed to fix the sleep issue for me. But like others here the battery gauge is still inaccurate. I don't even see values for the mWh in /batteryreport.
    Anyway, it got stuck at finishing installation at 33% on the Surface splash screen for like 2 hours - which I remembered having not taking that long to finish. Pushed the power button once and it was an endless reboot loop after. Called customer support here in Norway and he offered an exchange (albeit with a refurbished unit). He said it was easier to have it exchanged because this has been going on for a while. Which makes me wonder how bad this problem really is, and MS just keeping mum about it.
    Will be testing the replacement once I get it and offer my feedback here. Any suggestions what steps to take for those who got replacements and fared well with a new or refurbished slate?
    By the way, do any of you have problems with Touch Cover 2 not having sound feedback during typing? I saw on Device Manager > Other devices that there was an audio driver for the cover that just doesn't install successfully. I used online search and the Jan driver pack but it still fails to install.
    Surface Pro 2 is a great device when it works the way it should. When it doesn't, it's the most frustrating thing for consumers. Do you hear us Microsoft???
    I have 2 Type Cover 2's and I also get no sound feedback on either of my pro 2,s a 512 and a 256 version-- is this normal?
    Jack
    Still no click sounds anyone have any ideas?
    Jack
    2014-02-07T23:54:33+00:00
    Hey Jack,
    I got mine back on via Settings/Charms, Change PC Settings>PC and Devices>Typing>Touch Keyboard (ON=Play key sounds as I type)
    Then RESTART!
    It took a Shutdown/Restart to get the clicks back on.
    Good Luck!
