2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-13T02:04:42+00:00
    I have several Surface Pro 2 units with me (a  mix of 256 and 512 models).
    The FIRST unit got auto-updated to the 12/10/2013 firmware update, which I found out because the next time I picked it up I saw some of the drivers were unloaded, and I had to reboot.
    Like the other posters, this unit showed a "Failed" status for the firmware update in Windows Update history.  Battery status also appears less accurate (powercfg /batteryreport shows full charge capacity of 35,069 mWh vs design capacity 42,002 mWh).
    What's more, restarting or shutting down this unit now often leads to failure loading some device drivers, and I'd have to try this over and over until I get a successful boot.  The shutdown process itself often hangs, and I often have to hold the power button for a few secs to force it OFF.
    Here are the symptoms:
    • Device Manager shows Sensors > HID Sensor Collection with a warning icon, saying the device failed to initialize with the driver or something like that (I forget the exact wording).
    (Whenever the device driver does manage to load successfully, I noticed that the driver properties offer the option to "Roll Back Driver" even though this device appears to still use the initial v6.3.9600.16384 driver from 4/21/2009?)
    • Device Manager is missing Sensors > Simple Device Orientation Sensor which was previously shown
    • Event Viewer reports multiple Critical errors, including repeated instances of:
    1. "The device Surface Type Cover 2 Firmware Update Device (location (unknown)) is offline due to a user-mode driver crash.  Windows will attempt to restart the device in the shared process 1 more times before moving the device in its own process."
    2. Same error with Surface Cover Telemetry...
    3. "A problem has occurred with one or more user-mode drivers and the hosting process has been terminated.  This may temporarily interrupt your ability to access the device."
    2013-12-13T02:05:33+00:00
    Strangely, I also manually updated a SECOND unit with this firmware update as well.  Surprisingly, I did NOT encounter any errors this time, and Windows Update history showed the firmware update "Succeeded".  Battery status appears normal (powercfg /batteryreport shows full charge capacity of 41,968 mWh).  Repeated restarts/shutdowns haven't showed any anomaly in Device Manager.
    As it stands, though, I'm afraid to update the REST of my Surface Pro 2 units, lest they also encounter errors???
