2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-02T01:33:02+00:00
    The Flash had to get hit by lightning to become the F L A S H!
    The same way Spiderman got bitten.
    A battery expert is one who experienced battery explosion.
    Hahahhaa... just kidding.
    Perhaps everyone who's found this forum has been "bitten" by their SP2's..... Right?!  So now we all have superpowers..... (or at least we know a thing or two about Volume Up/Power Button and "powercfg /batteryreport" and CPUID.....
    2014-02-02T01:37:05+00:00
    Haha that's beautiful.
