2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-02T01:17:00+00:00
    ...a single battery drain to 0% wouldn't do any permanent damage if charged straight after it was fully drained.
    Yes I think that's correct (people do it all the time). But for me personally, the minor benefit doesn't outweigh the risks; particularly because I'm not in any way an expert.
    2014-02-02T01:24:27+00:00
    The Flash had to get hit by lightning to become the F L A S H!
    The same way Spiderman got bitten.
    A battery expert is one who experienced battery explosion.
    Hahahhaa... just kidding.
