2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-02T00:44:32+00:00
    Relative to draining the battery down, what is the Reserve Capacity in a Power Options plan all about?  It's typically set at something like 7%.  Does this mean when you drain your battery to "5%," it's actually at 12% of its total capacity because of the Reserve Capacity?  (5% + 7% Reserve Capacity = 12%??).
    EDIT:  Stopped being lazy and answering my own question.  The Reserve Capacity is the level at which WIndows notifies you it's about to Shutdown and you really need to find AC power.  So if your Critical Level is 5% and you set the Reserve Level to 7%, you'll get the Do or Die notice at 7% have 2% to run on before your device executes its Critical Level Action.  By upping the % for Reserve Level, you can give yourself more advance warning:
    http://windows.microsoft.com/en-us/windows7/how-do-i-change-the-low-battery-notification
    2014-02-02T00:51:26+00:00
    The wording sure is confusing. Read this thread from Microsoft Forum.
    http://answers.microsoft.com/en-us/windows/forum/windows\_7-performance/reserve-battery-level-what-does-it-do/90cbd429-f41e-4ecf-8eac-a5a53361f94a
    "Yes, it's a warning to save data to prepare for a forced shutdown. Documents in production are in danger of being lost. Many Word Processors will autobackup now and then for this reason.
    Rating posts helps other usersMark L. Ferguson MS-MVP
    Mark L. Ferguson MS-MVP"
