2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-02T00:34:24+00:00
    Phra,  cheers mate.
    I wonder if draining to 1% instead of completely drained would hold any advantage, or would it be the same to completely drain it?
    TheNewNormal, I'm assuming that a single battery drain to 0% wouldn't do any permanent damage if charged straight after it was fully drained.
    Draining to 1% does not calibrate the battery meter. In fact, like I said my unit ran for an hour after the battery meter hit 0%.
    2014-02-02T00:39:33+00:00
    I would never discharge to absolute zero. The only benefit is calibrating the battery meter, while there's potential to damage the unit.
    www.howtogeek.com/169669/debunking-battery-life-myths-for-mobile-phones-tablets-and-laptops/
    Great article!  Pretty much the battery use policy I have been following except I do not recharge my devices continuously but interrupt recharging for cooling if I feel the device is getting pretty warm from the battery heating up.  Another thought is the motto "sacrifice some use capacity now for long-term battery life and keep your battery charge state between 20% and 80%."  (if you do this, you are sacrificing 40% of your available battery capacity-20% at top and ~20% at bottom.  Save the times when you go from 100% down to 10% or whatever for those long airplane trips, if possible.
