2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-02T00:13:08+00:00
    Phra,  cheers mate.
    I wonder if draining to 1% instead of completely drained would hold any advantage, or would it be the same to completely drain it?
    TheNewNormal, I'm assuming that a single battery drain to 0% wouldn't do any permanent damage if charged straight after it was fully drained.
  2. Deleted
