2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-01T23:25:58+00:00
    Phra ,
    How was it that you got the battery to drain completely to 0%?
    I remember seeing it here somewhere on the thread, but don't have the time to scroll through every page.
    Tom.
    Draining battery to 0%:
    Go into power management.
    Set Critical Battery Level to 5%
    Set Critical Battery Action to Sleep rather than Hibernate.
    Manually wake the unit up when battery level reaches 5%
    The unit should stay on until depleted.
    2014-02-01T23:57:43+00:00
    Phra ,
    Tom.
    I would never discharge to absolute zero. The only benefit is calibrating the battery meter, while there's potential to damage the unit.
    www.howtogeek.com/169669/debunking-battery-life-myths-for-mobile-phones-tablets-and-laptops/
