2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-31T23:28:05+00:00
    Thanks for the feedback, David.  With me, I never noticed it until after the 12/10/13 firmware update.  It was sporadic until I completely discharged my battery on 1/29/14, and then Whammo!, it became a regular occurrence on opening my cover after sleeping.
    Also, the sequence of events that triggered it would change.  Normally, I seem to always mindlessly start Sleep by using the Charms, Settings, Power Button Sleep option, then close the cover (never mind that the Cover Close option is set to Sleep).  Perhaps this avoided a crash before.  After my 1/29/14 battery discharge/hibernate issues arising, it didn't matter if I started Sleep via the Charms Settings Power Button or just closed the Type 2 cover.
    So for me, the seeming total randomness of when and why such Surface Pro 2 issues arises can almost drive one to insanity.  If you know there is a problem and you find a workaround, cool.  But when suddenly for no good reason (other than poor Microsoft engineering), a new problem arises or the problem finds a way around the workaround.......  It's like playing Russian roulette daily!
    2014-02-01T21:09:46+00:00
    I have no other issue with the unit as everybody else describes here, except for a (compared to yours) very low battery life. 9 hours seems to be a bit exaggerated. How do you measure. I measure with an actual run of 5,5 h with office softwares before it shuts down, while you are maybe switching it on and off during the 9 hours period.
    Take a look at the other responses in this thread- your 5.5h of run life is way off.  Exceptionally low.
    See here on the CNET review.   They get 7 hours of run time playing video, which is pretty darn intensive.  So your 5.5 is abnormal. I'd look at a replacement.
    Battery life depends hugely on what you are doing.  If you are using the Metro side, you should get 8 hours or more.  If you're using the Desktop side, you can expect only about 5 hours.  Most lists of what to do to maximize battery life, which include tweaking screen brightness and turning off Bluetooth if you're not using that, are giving generic advice for Windows.  For people with a Surface Pro the main factor in battery life numbers is whether you are using mostly Metro or Desktop.
    So those who are mostly using Desktop can relax about their 5 hour experience.  And where possible, for simple web browsing, use the Metro side to get better battery life.  And when people discuss their battery hour data, it is crucial to estimate your Desktop/Metro ratio.
    Hopefully Microsoft service people know enough to explain this rather than go directly to doing an exchange or refund.
