2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-13T00:58:53+00:00
    I would try running "powercfg /batteryreport" at the admin Command Prompt as suggested by Vasan (and by myself in an earlier post) and look at the CAPACITY REMAINING COLUMN (not the Full Charge Capacity).  The results of batteryreport.html might also be erroneous because of the failed firmware update but it's worth a try to see if it gives you more accurate results.
    2013-12-13T01:35:29+00:00
    This latest version of firmware update also displays misleading battery meter percentage. The meter reports battery to be 100% full after every restart, power-on and wake. But returns to accurate reading after approximately 1/2hr of operation.
