2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-31T21:10:58+00:00
    Crash to hibernation associated with opening/closing Type 2 cover reared its ugly head again last night.
    Variety is the spice of life.  This time the shutdown seemed to occur upon OPENING my Type 2 cover after sleeping because for a tap or two on the Windows screen icon after opening the cover, there would be a vibration, then nothing, and I'd have to restart the SP2.
    May have found a way to fix the problem on my SP2.  Ran "powercfg /h OFF" - which turns off the ability to hibernate spontaneously.  (then closing the cover and opening it seemed to cause a complete Shutdown?!).  Then I ran "powercfg /h ON" - which turns hibernation capability back on.  I'm pretty ignorant about these things but I believe in the process of this command sequence, the original hibernation file is removed and a brand new one is created in its place.  Strangely enough, turning hibernation off, then on, seems to have solved the lid opening problems for now.
    Also wondered whether this problem arose because of my 1/29/14 complete discharge where I ran down the device until battery was very low and it shutdown, probably to hibernation since that is the default setting for Critical Battery Action for the Balanced Power Plan.  Perhaps the battery was so low, a corrupt hibernation file was created?
    May be specious reasoning on my part.  Don't know why one would get crashing while sleeping on opening/closing Type 2 cover if there is something wrong with hibernation file/hibernation conditions??  Eager to be better educated by knowledgeable folks.....  Also, if a thread on unwanted hibernation already exists somewhere on this forum, someone point me in the right direction.
    2014-01-31T23:03:54+00:00
    I reported this bug since day 1.  ALways is associated with EVENT ID 41 when waking or going to sleep(usually waking if you check the timing of the logs) when opening or closing or pushing the power button.  Of course you loose all unsaved data when this happens and the system reboots.  most people don't realize this is happening until you look closely and search your logs for EVENT ID 41.     I have had 4 surface pro 2's so this is obviously a software issue still unresolved.
    People need to start returning these devices in droves before Microsoft will finally fix some of these deal breaking bugs.
