2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-31T06:33:04+00:00
    How do you find these firmware version numbers?
    I just had my Surface Pro 2 finally exchanged. The USB port on my original one was not working correctly. I did a in store exchange.
    I ran Windows update and it wants to install the January 18th Firmware update. The guy at the store told me this should have the latest firmware and updates but I am not surprised to see it wants to install some.
    The Big Question:  Should I install this firmware update, or wait and see how the device is behaving first. I would like to know what firmware it came with?
    I can't see it coming with the faulty December firmware so I am guessing it has the firmware from October.
    2014-01-31T06:56:22+00:00
    Aren't you lucky? I am the silly wall hitter and I have just stumbled into the same booby-trap. I have a sticker on my four head saying do not rob my experience. And guess what? Do not and I mean DO NOT install the firmware update.
    My SP2 started much faster, ran a lot cooler with the stock factory firmware. I only updated due to two issues...
    1. With an SD card inserted, the screen brightness with default to 100% every cold boot.
    2. Cold booting with an SD card inserted, the Client Server Run-time process (csrss.exe) would chew my CPU to shred making the machine stutter. Updating to the January firmware meant replacing the csrss.exe horror with System and System Interrupt chewing the CPU instead which doesn't stutter the unit. Remember the UAE in Windows 3.1? It only gets replaced by General Protection Fault in windows 2000. Haha. Typing on a mobile device, Hope I make sense.
